Author Topic: [OBSOLETE] API Docs, HowTo's etc..  (Read 11584 times)
e-motiv
[Edit]
OBSOLETE!!
Everything is here now:
http://musicbee.wikia.com/wiki/API_Documentation
http://musicbee.wikia.com/wiki/API_method_reference
First check this post and download the latest example files for your choice of language:
Then get the latest weekly Musicbee build:
Here is my "very basics" for starting with the MB API, based on help from people on this forum:
Feel free to add API howto's to this thread. (No discussions please.)
Last Edit: June 30, 2013, 03:07:21 PM by R U Bn ?
  Developing @ e-motiv.net       --       Musicbee plugins: Speak Back - Ghost Tracks - Radio Dig
e-motiv
Trial to get a function help / reference. Please update this list if you find the time:
  • Please update this list if you find the time:
  • void MB_Releasestring(string p1);
  • void MB_Trace(string p1);
  • intPtr MB_WindowHandle();
  • void MB_RefreshPanels();
  • void MB_SendNotification(CallbackType type);
  • void MB_AddMenuItem(string menuPath, string hotkeyDescription, EventHandler handler);
    For use with boroda tag tools
  • string Setting_GetFieldName(MetaDataType type);
  • string Setting_GetPersistentStoragePath();
  • string Setting_GetSkin();
  • int Setting_GetSkinElementColour(SkinElement element, ElementState state, ElementComponent component);
  • bool Setting_IsWindowBordersSkinned();
  • string Library_GetFileProperty(string sourceFileUrl, FilePropertyType type);
  • string Library_GetFileTag(string sourceFileUrl, MetaDataType type);
  • bool Library_SetFileTag(string sourceFileUrl, MetaDataType type, string value);
  • bool Library_CommitTagsToFile(string sourceFileUrl);
  • string Library_GetLyrics(string sourceFileUrl, int type);
  • string Library_GetArtwork(string sourceFileUrl, int index);
  • bool Library_QueryFiles(string query);
  • string Library_QueryGetNextFile();
  • int Player_GetPosition();
  • bool Player_SetPosition(int position);
  • PlayState Player_GetPlayState();
  • bool Player_Action();
  • float Player_GetVolume();
  • bool Player_SetVolume(float volume);
  • bool Player_GetMute();
  • bool Player_SetMute(bool mute);
  • bool Player_GetShuffle();
  • bool Player_SetShuffle(bool shuffle);
  • RepeatMode Player_GetRepeat();
  • bool Player_SetRepeat(RepeatMode repeat);
  • bool Player_GetEqualiserEnabled();
  • bool Player_SetEqualiserEnabled(bool shuffle);
  • bool Player_GetDspEnabled();
  • bool Player_SetDspEnabled(bool shuffle);
  • bool Player_GetScrobbleEnabled();
  • bool Player_SetScrobbleEnabled(bool shuffle);
  • string NowPlaying_GetFileUrl();
  • int NowPlaying_GetDuration();
  • string NowPlaying_GetFileProperty(FilePropertyType type);
  • string NowPlaying_GetFileTag(MetaDataType type);
  • string NowPlaying_GetLyrics();
  • string NowPlaying_GetArtwork();
  • bool NowPlayingList_Action();
  • bool NowPlayingList_FileAction(string sourceFileUrl);
  • bool Playlist_QueryPlaylists();
  • string Playlist_QueryGetNextPlaylist();
  • PlaylistFormat Playlist_GetType(string playlistUrl);
e-motiv
NotificationType.TrackChanged means that the player changes track (to another), not the track itself being changed
e-motiv
In build file,reference MB dll:
			<references>
        <include name='C:\Program Files (x86)\MusicBee\System.Data.SQLite.dll'/>
</references>
In plugin, just SQlite away:
using System.Data.SQLite; //http://system.data.sqlite.org
pluginDBFileName = mbApi.Setting_GetPersistentStoragePath()+sep+about.Name+".db";
DB = new SQLiteConnection(@"Data Source="+pluginDBFileName);
DB.Open();
