Author Topic: 'Smooth Tuned' 5 skins  (Read 15237 times)
Greb
Just a small tweak over the really good smooth grey skin from Rotem K.
DOWNLOAD LINK (NEW VERSION): http://www.mediafire.com/?7pc49i15401zewi
LINK UPDATED March 26th
DOWNLOAD LINK (OLD VERSION): http://www.mediafire.com/?dpg45cvkd49rg3a
LINK UPDATED March 17th. I discarded dependant skins as long as I was not able to make one of the elements to get the right colour. I added a couple of minor colour tweaks.
Instructions:
1. Extract the whole folder and place it in 'Musicbee\Skins', so the skins should be in 'Musicbee\Skins\Smooth Tuned'
IMAGES (NEW VERSION)
Smooth Tuned Blue A
Smooth Tuned Blue B
Smooth Tuned Clear Grey
Smooth Tuned Medium Grey
Smooth Tuned Dark Grey
IMAGES (OLD VERSION)
This is the original smooth grey (just a bit changed):
This is the blue version:
And this is a darker version:
Medium dark version:
Last Edit: March 26, 2011, 07:43:43 PM by Greb
VX
Greb, thank you for the skins. Clear Grey is one of my favourites  :)
I discovered a small bug in a few of the skins (Smooth Tuned Blue A and B, Clear, Dark and Medium Grey).
When you launch the tag Editor the top bar commands (Undo, Tag Inspector... etc.) are invisible until hovered over.
Greb
I haven't this problem, or I'm not able to find it  ???
Can you upload a screenshot?
if you open the Tag Editor in a floating window (right click/ Edit)
the problem is that the buttons in the top of this window share the same foreground properties as the right click context menu. This works fine in most cases, but in this case not. So for the next update i've added a new element to override the text which you would need to set:
  <element id="Toolbar.MenuTextOverride" fg="0,0,0" />
Greb
troglodytes16
Please, could you re-upload this skin? All links are dead  :-\
Bookbear
I'm noew to MusicBee and liking it a lot... but the links to this skin all seem dead?  Is there any way I could get this skin from someone who successfully downloaded it in the past.  I really like the layout, but am not having success in creating one of my own like it.
Thanks!
