Author Topic: file types to include in library  (Read 8398 times)
kapblat
a checkbox for what filetypes to include in library
because for example i have some mpgs that i dont want to include in the library
and it keeps re-adding them (to the inbox) every time i start MB
fair enough, although i thought i had stopped it from importing files with video extensions. What's the exact file extension(s) you have this behaviour?
it should already be filtering out .mpg files (i fixed that a few releases ago) - can you confirm its still doing it and those arent old files you loaded from an earlier release?
kapblat
yup, using new install, 1.0.3418, clean library directory.
they're .MPG video files
they show up with a (!) next to it in the library, (!) says "MPG files are not supported for playback"
i'm deleting them from library
and on rescan it keeps re-adding the .mpgs
on shift-enter it says > properties> type "MPG audio file"
seems i didnt remove it from the configuration file
if you copy this file to your musicbee program folder it should fix it
http://www.mediafire.com/?rzlae2fwtfy
