Author Topic: Display the formatted title instead of the title in the main pane  (Read 2310 times)
Antineutrino
How can I display the formatted title instead of the title in the main panel? Titlenr. and title cannot be changed?
Sorry, I'm having a language barrier here.  Do you know what those fields are in English?  (A full screen screenshot might also clear it up)
@Antineutrino
also you could temporary switch mb to english and make screenshot.
Oh, I found it.  It's the expanded panel configuration.  What I'm not clear on is what you mean by "formatted title"?  Is that like Sort Title?
no, its new tag in latest mb 3.1 patch, mostly for classical music. it includes movement #, etc.
Shouldn't that be happening automatically, the same way as in tracks/album & tracks?  If not, then yes that seems like it should be fixed.
