Author Topic: MusicBee 3.1  (Read 147134 times)
**** see the last post for the latest update ****
Follow https://twitter.com/MusicBeePlayer for notifications when updates are made available
Last Edit: September 16, 2017, 11:07:04 AM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_1_6275.zip
backup:
http://www.mediafire.com/file/tuaiwcmoenlua9o/MusicBee_Setup_3_1_6275.zip
this is an incremental update and includes all changes since version 3.0 - unzip and then run MusicBee_Setup_3_1_6275.exe
-the following are no longer custom tags and now have dedicated tags: "Title Sort-Order", "Album Sort-Order", "Album Artist Sort-Order", "Artist Sort-Order", "Composer Sort-Order", "Language", "Original Artist", "Original Album", "Original Year", "Musician Credits List"
    - The various Sort tags are now editable in a new "Sorting" tab in the tag editor
    - Original Year, Title and Artist are now standard tags in the Tags(2) tag editor panel
    - Musician credits are now editable in the Artist tag splitter (click the ... button by the Artist tag)
    - the library database: musicbeelibrary.mbl is copied to musicbeelibrary.preupgrade in case you need to undo the upgrade and revert to an older MB version
- The behaviour of the various Sort tags (Sort-Artist, Sort-AlbumArtist, etc) has been changed so when sorting by Artist, MusicBee will now automatically use any Sort-Artist tag value for the sort operation. Note that if an album is not consistently tagged with the same Sort-AlbumArtist then it will be split
- Classical music tags: Work and Movement are now supported (click the arrow button on the title prompt)
- long filenames (>260 characters) is now supported
- Playlists panel enhanced to support multiple levels of folders and provide the full functionality equivalent of the left navigator playlists
- Playlists can now also be displayed in a standalone panel (set in the Panel Arrangement dialog)
- New Volume visualiser panel (Peak and VU)
- New Graphics visualiser panel (allows the Milkdrop visualiser to be displayed in a panel)
- Spectrum visualiser can now be displayed using a centered frequency range
- Inconsistent tags "Files to Edit" filter now includes the Album Gain tag
- New "Album Played" display tag
- Panel layout is enhanced so each panel header can optionally be hidden
- New Hotkeys for the following:
    - Send files to the active device
    - Send files to the active playlist
    - Toggle playing tracks to show the upcoming tracks
- Drag/drop is enhanced so you get a visual representation of the number of files being dragged and a message showing what action would be taken if you dropped the files on a panel
- Artwork layout now allows the selected tracks to be displayed to the right of the main panel
- Nested filter rules in auto-playlists can now be set as an "And" or "Or" condition
- Auto-playlists can now be set to automatic or manual refresh of the matching tracks
- New Album Artwork Manager tool, enables you to view and correct a variety of inconsistent album artwork conditions
- You can now disable the display of the current playing track in the windows Taskbar popup (this addresses a windows display issue when alt-tabbing)
- New "Remove Cuesheet" right click menu item
- new naming template functions:
    - $RxReplace(<field>,"reg-ex search pattern","regex-replacement pattern")
    - $RxSplit(<field>,"reg-ex search pattern",index)
- the virtual tag/ file naming template field editor can now Preview the results of any template you define
- the Playing Tracks panel can now show Upcoming Tracks
- the Library Explorer can now display and navigate the folder structure of files in your library
translator file - updated new.txt file (this file is only used by translators and not required for the MusicBee application update):
http://musicbee.niblseed.com/Localisation/new3.1.txt
edit:
links updated with some tweaks to the custom tag upgrade process and a few bug fixes
Last Edit: June 24, 2017, 10:44:19 AM by Steven
there is a bug in MusicBee v3.1 (for several months I estimate) when saving multiple files in the tag editor and:
- you didnt update any artwork;
- and the file had no embedded artwork
if both of those were true then the tags were not being written to the files ie. only the MusicBee database was being updated. This bug did not happen when saving one file in the tag editor - its only happened for multiple files being edited at the same time.
The above link has been updated with the fix.
The assist with re-saving any files that might have been affected, I have enhanced the "Synchronise Tags" function:
- select the files you want to check
- from the main menu/ Tools/ Advanced/ Synchronise Tags...
- MB will scan the selected files and check the file tags for inconsistencies with the MusicBee database
- if there are any files detected, the filename is written to the error log and you will be prompted to confirm you want the files to be re-saved
- if you click No, you can manually edit the files by checking the filenames in the error log
- if you click Yes, MB will re-save the tags to the relevant files
See the above post for the fixed MusicBee version
Last Edit: March 10, 2017, 06:04:01 PM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_1_6345.zip
backup:
http://www.mediafire.com/file/w9bfeqwrzzryal0/MusicBee_Setup_3_1_6345.zip
- custom file sorting (Sort Artist, Sort Album etc) is now configured within the MusicBee database rather than being primarily based off file tags. See https://getmusicbee.com/forum/index.php?topic=21624.0 for more details
- option to have an entire music file loaded into memory. Set in the Player preferences
- option to exclude specific sub-folders from library folder monitoring. Set in the Library preferences
- more information on when podcasts have been refreshed and when the refresh fails
- Locate missing files tool available from Tools/ Locate Missing Files
- Folder (name of the folder the music file resides in) can now be viewed in the column browser and thumbnail browser. The full Folder structure is already supported in the Library Explorer
- various bug fixes and other new features
edit:
updated the links to fix a couple of bugs
edit2:
updated to fix a relative file path bug when reading m3u playlists
Last Edit: June 24, 2017, 10:43:59 AM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_1_6388.zip
backup:
http://www.mediafire.com/file/v8xbiif1de9gela/MusicBee_Setup_3_1_6388.zip
this is an incremental update and includes all changes since version 3.0 - unzip and then run MusicBee_Setup_3_1_6388.exe
- Computer folder structure browser panel that enables you to browse music files by directory structure, and can be enabled in the Panel Arrangement dialog
- Album Colour Mix skin in the Now Playing panel now includes an artist picture
- new Inconsistent Sort Tags filter in the Tagging Tools (Tools/ Tagging Tools/ Other Files to Edit/...)
- sort thumbnail browser items by Album or Track count
- Expanded Artwork panel now has an option to show and select from all album covers associated to the playing album
- Tracks With Thumbnail view in the Playing Tracks panel now has the option to not show thumbnails so you can acheive multi-line text for each track
- device sync can now disable splitting of cuesheet files when synching
- new Hotkeys for:
    Tools: Locate Missing Files
    Player: Toggle Equaliser On/Off
    Player: Toggle DSP On/Off
- numerous skinning and theater mode enhancements that will be used by various new skins
- various bug fixes
edit:
links updated to fix a bug with the tempo dsp
edit 2:
the full beta install is now available on the downloads page
Last Edit: June 28, 2017, 08:15:56 PM by Steven
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_1_6427.zip
backup:
http://www.mediafire.com/file/wr922bpycswyzsq/MusicBee_Setup_3_1_6427.zip
An incremental update and includes all changes since version 3.0 - unzip and then run MusicBee_Setup_3_1_6427.exe
This is the last planned 3.1 beta version ie. is feature complete and the only changes will be bug fixes
edit:
updated with several minor bug fixes
Last Edit: August 06, 2017, 11:53:50 AM by Steven
First release candidate:
backup:
or the full download, including updates to skins and localisations
http://www.mediafire.com/file/zn6p3zarskae6qq/MusicBeeSetup_3_1_RC1.zip
portable:
http://www.mediafire.com/file/8iu330v7almdlmx/MusicBeePortable_3_1_RC1.zip
Last Edit: August 06, 2017, 08:50:49 PM by Steven
Second release candidate:
incremental update and includes all changes since version 3.0 - unzip and then run MusicBee_Setup_3_1_6445.exe
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_1_6445.zip
backup:
http://www.mediafire.com/file/j634ghvz897gdj7/MusicBee_Setup_3_1_6445.zip
http://www.mediafire.com/file/piw4o9r18cwt44o/MusicBeeSetup_3_1_RC2.zip
portable:
http://www.mediafire.com/file/oow6hs4tlglm5wm/MusicBeePortable_3_1_RC2.zip
edit:
small bug fixes
Last Edit: August 24, 2017, 06:12:56 PM by Steven
Third and hopefully final release candidate:
incremental update and includes all changes since version 3.0 - unzip and then run MusicBee_Setup_3_1_6454.exe
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_1_6454.zip
backup:
http://www.mediafire.com/file/pa6hmf6p8afgp97/MusicBee_Setup_3_1_6454.zip
http://www.mediafire.com/file/cpe4edimg2d9u1h/MusicBeeSetup_3_1_RC3.zip
portable:
http://www.mediafire.com/file/qvom9cum9wlfq8i/MusicBeePortable_3_1_RC3.zip
A few more bugs fixed, a couple of which i think warrant another Release Candidate:
incremental update and includes all changes since version 3.0 - unzip and then run MusicBee_Setup_3_1_6462.exe
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_1_6462.zip
backup:
http://www.mediafire.com/file/i47ldlk4aa8yhbc/MusicBee_Setup_3_1_6462.zip
http://www.mediafire.com/file/ntwpfz0e32bas1b/MusicBeeSetup_3_1_RC4.zip
portable:
http://www.mediafire.com/file/88m44aa4v50vmsh/MusicBeePortable_3_1_RC4.zip
This is the final planned release for v3.1
incremental update and includes all changes since version 3.0 - unzip and then run MusicBee_Setup_3_1_6466.exe
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_1_6466.zip
backup:
http://www.mediafire.com/file/uylya5b4u00083b/MusicBee_Setup_3_1_6466.zip
http://www.mediafire.com/file/dsbd678vdozzuvp/MusicBeeSetup_3_1.zip
portable:
http://www.mediafire.com/file/t73mdtqqro7gsq7/MusicBeePortable_3_1.zip
Update 1 which bug fixes and minor speed improvements since the official release
incremental update and includes all changes since version 3.0 - unzip and then run MusicBee_Setup_3_1_6512.exe
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_1_6512.zip
backup:
https://www.mediafire.com/file/n1b3m43l57olb7f/MusicBee_Setup_3_1_6512.zip
https://www.mediafire.com/file/jfqsfat1sgmm55w/MusicBeeSetup_3_1_Update1.zip
portable:
https://www.mediafire.com/file/zr4gcb3cfb5ntge/MusicBeePortable_3_1_Update1.zip
edit:
links updated to fix a bug with the silence remover DSP
Last Edit: October 30, 2017, 09:58:20 PM by Steven
Update 2 where groove music has been replaced by the iTunes store in the Music Explorer and various other important bug fixes
incremental update and includes all changes since version 3.0 - unzip and then run MusicBee_Setup_3_1_6585.exe
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_1_6585.zip
backup:
http://www.mediafire.com/file/ztae4pshw5s6d3g/MusicBee_Setup_3_1_6585.zip
http://www.mediafire.com/file/popd8bvnq62bz5t/MusicBeeSetup_3_1_Update2.zip
portable:
http://www.mediafire.com/file/84ng37dsjvo15fe/MusicBeePortable_3_1_Update2.zip
edit:
links updated with small fix for the music explorer
Last Edit: January 11, 2018, 07:06:51 PM by Steven
There was an introduced bug in the last update that incorrectly reports some files are being corrupted so I am doing another update
incremental update and includes all changes since version 3.0 - unzip and then run MusicBee_Setup_3_1_6590.exe
http://musicbee.niblseed.com/Weekly/MusicBee_Setup_3_1_6590.zip
backup:
https://www.mediafire.com/file/idhap8jpw6c7lpf/MusicBee_Setup_3_1_6590.zip
https://www.mediafire.com/file/d3fr20dmkwp35aj/MusicBeeSetup_3_1_Update3.zip
portable:
http://www.mediafire.com/file/acw8fo5otjhocof/MusicBeePortable_3_1_Update3.zip
