Author Topic: Spotify's Accent Dark  (Read 19937 times)
nobuyback
DOWNLOAD
*Original icons designed by RealPetChicken
Last Edit: February 05, 2017, 09:10:38 PM by nobuyback
supaflanka
  • fortis Fortuna adiuvat
How do you get the bad ass bee icon on the top left corner?
Xenatier
In the general tab of preferences, you can select the icon from there.
NormieLyfe
NormieLyfe
Hey I wanted to point out the check box color isn't green but here's a -180 Hue of it
  <element id="CheckTick">
    iVBORw0KGgoAAAANSUhEUgAAAAcAAAAHCAYAAADEUlfTAAAAZElEQVR42mNgwAUmKL7BFOwVkgVLTFb6z8DQI6GFkFBSY5io8BQsMUFxNUj7M4ZeRX2GNh5RhgnKjxASIDBZ+T/DJOXbDBOVboHZE5RnIFvsBxYEK1KagcVlsuFARVuALCZkYQBEuyOmwg1l/AAAAABJRU5ErkJggg==
  </element>
wealstarr
computerninja
What are the plugins/visualisers you're using on the bottom that look like how Soundcloud does their view of the wavelengths? Also, the wide bar meters. Just installed Musicbee an hour ago and want to know a few of these basics. Thanks.
SandaruLJ
Why are Mini Player's Star Ratings not coloured in green?
Terry Walker
frankuaku
  • MusicBee lover
Marvelous theme! Anyway, could you insert in the skin download the green bee icon? I tried to edit the "plain" icon of the set you mentioned but I had no success.
Hombre-0
I'm pretty new using musicbee (this skin is the second plug-in I added), and everything is fine except the main player control: it is not like the picture (black, green, grey), the panel is soft blue with white keys. Why is that?
Thanks in advance.
Hombre-0
Can you post a screenshot?
Sorry for posting hastily, I've found the solution.
When you activate the skin you can see an extra option in the main player control bar: automatic background color. If you desactive this option, then you can see the correct skin for the main player control.
Thanks for your interest, I post the solution in case another newbie like me has the same problem.
