the bug for the first issue is fixed for the next v3.1 update.
For the second issue, i think its probably the same thing
The second error is not solved, and related error in the mode "Album Covers" and "Artists" are not saved fields "Set Displayed Fields ...".
Quote from: Sofocl on February 05, 2017, 12:29:18 AMThe second error is not solved, and related error in the mode "Album Covers" and "Artists" are not saved fields "Set Displayed Fields ...".that should be fixed for the next v3.1 update
