Author Topic: Future Shock  (Read 6384 times)
  • MB Version: 3.6.9255 P
ATTENTION!
This skin has been updated for use with MusicBee 3.2.
It is not compatible with version 2.5 or earlier.
Wave Bar feature is only available if using 3.1 version or later.
Background image is only selectable with 3.2 version.
Auto-colour player bar is only available with 3.2 version.
Future Shock
This is the updated version of 'Scamelon'.
For the 3.0 upgrade I went back to the original Media Monkey 'Mellon' skins and decided I wasn't truely happy with those really strong colours - especially the green.
So I toned down the shades used and remade this skin for MB.
During the original collaboration between psychoadept, BinghiFire and myself, BinghiFire told me that mellon meant future in Greek and that was his inspiration for the title of the skin.
Well, they both will probably be shocked and appalled at what I have done to the skin, hence my skin title  ;D
standard view
background image and auto-colour player bar ON
Updates
July 19, 2018:
  • MB3.2 update;
  • selectable background image added;
  • minor change to player bar to allow auto-colouring;
  • svg icons for high DPI screens used;
  • 3.1/3.2 icons added.
September 14, 2016:
  • from original Scamelon skin;
  • softening of bright colours;
  • MusicBee 3.0 changes incorporated;
  • player bar controls reversed, now LH aligned;
  • 'No Artwork', 'Unknown Artist' and splashscreen images optimised for smaller file size;
  • icons updated and changed;
Downloads
Download from Skins section of MusicBee Add-ons here
Skin installation instructions and other information can be found on the wiki
Any positives, negatives or errors found, just drop a line below.
Enjoy  :)
Last Edit: July 19, 2018, 07:53:50 AM by Bee-liever
Updated for MB 3.2
Link and details in first post
