Author Topic: Unable to start MB3  (Read 3866 times)
settra
hey! is there a downloadable version that supports touch scrolling in artist view?? (i downloaded the above link but it doesent have something )
thanks!
Last Edit: January 21, 2016, 05:46:41 PM by Steven
thanks!
MB3 supports touch scrolling. Are you sure you downloaded the link in the first post and ran MusicBee3.exe
settra
thanks! but for some reason, i cant seem to be able to run musicbee3.exe
when i double click it, nothing really happens.
the program IS running, becouse if i try to move/delete the musicbee3.exe it says "its being used by the system" , but no windows show up whatsoever..
any idea?
any idea?
Did you copy it and all the files into your MB installation directory?
settra
yes! 3 files in total, right? (and the skins folder)
Alumni
any idea?
It might be security related - try right clicking the executable (MusicBee3.exe) and tick the checkbox that says "unblock".
settra
i dont know. when right clcked, it dosent have any "unblock" options.  the musicbee3.exe, should be in the same folder as the musicbee.exe , correct??
weird thing is, that even though it dosent show up in the "detalis" in task manager,
it still dosnet allow me to delete the executable... (wich means it is being used by something)
it sounds like your security software is blocking MB - Avast seems to cause many problems. If you are using that. then add MB as an exception
settra
cool! i AM usining avast. will get on my PC tommorow and post results! thanks!
And in case Avast isn't the reason, go back to the above and when right-clicking on the exe, select properties and then unblock.
