Author Topic: Bleached Bone  (Read 18507 times)
  • MB Version: 3.6.9255 P
Bleached Bone
A neutral beige skin based on the colour Bone, with just a touch of blue to represent those bright, sunny skies.
Designed for MusicBee3.0 and above.  Compatibility with version 2.5 or earlier is not guaranteed.
View shows some new MB3.1 elements
Matching themed "No Artwork" and "Unknown Artist" images included.
Updates
October 13, 2016:
  • MusicBee 3.0 release version changes incorporated;
  • blue "highlight" scrollbars added;
  • minor tweaking of colours;
  • themed Artwork and Artist images updated;
  • 'No Artwork', 'Unknown Artist' and splashscreen images optimised for smaller file size;
  • icons updated.
Downloads
Download from Skins section of MusicBee Add-ons here
Skin installation instructions and other information can be found on the wiki
Last Edit: December 05, 2016, 12:44:49 AM by Bee-liever
Very nice (of course) Bee-liever!
But, I kind of would expect the bleached skeleton of The Bee in the splash screen...
And, of course I just had to find and comment on something:
The background color of custom buttons would probably be even nicer if they were the exact same color as the search field.
Since you asked so nicely  -  your wish is my command.  :)
File updated in link.
BTW...
I couldn't find a copyright free image of a bee exoskeleton that didn't just look creepy.  ;D
Whats wrong with creepy?
You are a creative guy, you could start-off with something like this ;-)
MeeMeeMee
Very nice. Where can I find those icons in the screenshot?
MusicBee 3.6.9154 / Windows 10 (64-bit) / Intel i5-3470 / 8GB RAM
Media on NAS (CIFS share)
Get the latest patch: https://getmusicbee.com/patches/
Sorry MeeMeeMee, I thought I'd posted those toolbar icons before but I obviously forgot too.  ::)
They are now posted here.
MeeMeeMee
Thank you!
Mr. Trev
Awesome skin! It's now my go-to for 3.0 (just need to figure out how to make the most of it - 3.0, that is)
Thanks.
Minor update
Details in first post
For download, see Add-ons section or link provided in first post
Mr. Trev
Fine work as usual. This is still my goto skin!
Thanks
Mr. Trev
A small critique
I just found out that if you use the narrow scrollbar option, the scroll bars are nearly invisible with the default colour
nehzul
Hello Bee-liever,
I'm a new user and have just installed music bee from the homepage. I wasn't fond of the default theme so I searched the skins section and discovered your beautiful work. I installed it and already... a much better pleasant experience of the user interface.
One question. I've spent the last half hour trying to play with the appearance panels to get the same look and layout as yours, but I'm failing and do not want to learn to customize it. Is it possible for you to share a settings file that will allow me to trigger the same look and layout as you have displayed in the picture in your main post? Also, is this still the layout you're using or have you made it better?
Thanks!
Hello nezhul,
Sorry for the wait!
Have sent you a PM.
Mr. Trev
HI.
I've found that this skin seems to have some issues with the latest betas (3.5.8258 P). I've posted some pics over on this thread: https://getmusicbee.com/forum/index.php?topic=37018.0
I don't know if you're still active working on your skins, but I thought I'd bring it to your attention anyways
