Author Topic: Hotkeys  (Read 5633 times)
2525
Hi!
I use global hotkeys a lot, and I like that MB has a vast collection of user assigneble hotkeys.
I do though have some things I'd like to add/change.
First off, since the last update (1.2.3875 Beta) the "skip forward/back 10 seconds" hotkeys have got really laggy. The time bar moves right ahead in the player when I skip, but it takes about 1 second for the actuall sound to skip forward/back. Maybe not that big of a deal, but it's annoying me rather much.
Now on to things I'd like to see added/changed:
About the just mentioned "skip forward/back 10 seconds" hotkeys, I think 10 seconds is a too big leap. It would be nice to be able to give a user defined value, or just shorten it to 5 seconds.
Within the first 10 seconds of a song the "skip back 10 seconds" doesn't do anything. I think it should be better if it would go to the beginning of the song instead.
The hotkeys for "volume up/down" have a little too big impact in my opinion. Would be nice with a user defined value here too, or just decrease the amount it changes.
I'd like to see a hotkey for toggle the shuffle button on/off.
That's my two cents.
Thanks for a good player!
for the next update the sound latency should be fixed
the skip interval is now 5 secs
and the skip back goes back to 0
also hotkeys for toggling shuffle and repeat have been included
no change to the volume as yet
2525
