what extension are they and do you have continuous monitoring enabled
They were MP4, FLV, AVI and MPG.
Continuous monitoring is enabled. Actually, that may have been the culprit because doing a manual rescan now doesn't show them.
this should fix the issue - unzip and replace the existing musicbee files:
Awesome. Thanks for the fast response. I'll give the new version a go.
On a possibly-related note, I'm incrementally moving my library to a new drive and now when I do a manual rescan it seems to take a lot longer than it used to. A lot of that time is after the counter in the status shows it's scanned all of the tracks on my drive. Then I get prompted to remove "missing" tracks from my library. However, these aren't tracks in my library (because I haven't moved them over yet) but they are referenced in playlists. I also only just realised if I say "Yes" it removes them from the playlist too, which was a little worrying.
Is this expected? I always thought tracks in the Library and the playlists were kept separate for things like scanning. There are tracks missing but it's only temporary so I'd rather MusicBee didn't spend any time checking the playlists at all. Again, I definitely have "Include playlists" unchecked - and I don't think that applies to MusicBee's own playlist folder anyway.
