Author Topic: MusicBeeIPC - Control MusicBee with Autohotkey, Python, Java, etc  (Read 76550 times)
snwflake
Hi, I just found out about this plugin but unfortunately, when I tried to download the .zip file, I found out Zorexx's server no longer exists. does anyone know where I could download the files? Cheers! :)
Links are working perfectly fine? https://kerlilow.me/files/downloads/MusicBeeIPC.zip
The wiki is just outdated, but that is always the case.
Link is broken ... so sad
You're probably out of luck as the last time the plugin developer was on the forum was March 11, 2017.
mrbenn
Found a partial set of the files via Wayback Machine which I have uploaded here: https://www.mediafire.com/file/tk7ytb4hud4hta7/MusicBeeIPCrec.zip/file
It has the source, the plugin and the SDKs for Python and C++
I wasn't able to find the other SDKs etc.
Hope this helps!
mbdiener
Thanks for posting this. I had almost given up on finding a copy of the plugin. It seems to work fine on Windows 10 along with Audioband even though the plugin is around 8 years old. Thanks again!
Hope this helps!
NighTeagle
FYI for other users of this plugin:
I encountered an issue where this plugin prevented a correct shutdown and restart of Musicbee 3.5:
https://getmusicbee.com/forum/index.php?topic=36499.0
I have not tested whether the plugin functionality still works on MusicBee 3.5, but I doubt it given this experience.
The plugin did still work with MusicBee 3.4.
Perhaps it's related to the upgrade to .NET 4.8 of MusicBee 3.5.
i've added this plugin to add-on's section of mb site. thanks to @mrbenn for recovering lost plugin's archives!
https://getmusicbee.com/addons/plugins/486/musicbee-ipc/
