Author Topic: Option to move Playing Track Details in the right sidebar, with lyrics below  (Read 2933 times)
basshead
1st, the bug: The Wave bar and Spectrum visualizations from Playing Track Details are visible only when the Playing Track Panel is in a Tab and not when it is in the Bottom Pane. I remember that in first 2.1 beta versions they were visible in both instances.
that was the case very early on but it was later taken out as the layout was changed. It would only work in the bottom panel layout if the height of the panel is sufficient (as it would be in your case) but for most people not.
You should put this and the next item in the wishlist section.
2nd, the request: As you can see, i use the "Album and Tracks" display in my main panel and i sort my music by "Album Artist / [Year] Album". I use Library Explorer from left sidebar to search for artists/albums, and i use my right sidebar for Now Playing Track Info and Lyrics. But i like much more the (Album Artwork + Playing Track Info + Wave bar + Spectrum Visualizations) inside Artist Photos way of display form Playing Track Panel rather than left sidebar Playing Track Panel Config.  I don't want to have anything else than albums and tracks in my main panel so can u give the option to move the Playing Track Details in the right Sidebar please?
Like this:
