Author Topic: LyricsReloaded  (Read 238818 times)
VX
I tested all sites I added on MusicBee 2.1 pre1
Perhaps someone else could test if the plugin works with MusicBee 2.1 pre1  ??? I have removed the pre1 build so I can't help with testing.
quick_wango
  • Software Engineer
Just a quick update on the progress of 1.1:
I almost completely rewrote the plugin and it's now in the state, where is compiles, but doesn't work yet.
You can see version 1.0 as some kind of teaser, 1.1 will be the first proper release.
  • MB Version: 3.6.8830 P
thanks for oldielyrics.com
salome
Wow, thanks for planning to add http://www.jpopasia.com/ ! I really appreciate it ! ;D
quick_wango
  • Software Engineer
Hi there,
Downloaded the plug in. Installed it in the plugin dir, but after restarting MB the program says it cannot load the plug in. I have the latest MB version. What went wrong?
Could you be more specific about the error?
topol-m
Here is .yml file for site "tekstovipjesama.com" with data base ex-Yu speaking language songs.
http://www.sendspace.com/file/3ehnjk
When reading character " ' " it returns " ’ ". Except that, everything seems to works fine.
Is there a way to change priority of sites? I have significant lagg while plugin go trough all sites, and find nothing until he came to very last site (in my case: "tekstovipjesama.com") and find text.
Last Edit: June 25, 2013, 03:39:27 PM by topol-m
ron505
Hi there,
I've copied the file into the plugin directory.
When i open MB / Preferences / plugins i see the notifications that the plug in is on the machine, but when i want to enable it, it says the file has been blocked. Then i deinstalled it and tried it again, same result.
quick_wango
  • Software Engineer
have you tried adding the entity_decode filter? That might resolve the problem.
May I add the configuration to the default configuration?
If not, you will have to update for the new version of the plugin probably coming during the next week.
topol-m
Thanks.
Filter "entity_decode" fix it.
Here is link on new ".yml" file
http://www.sendspace.com/file/q1lplp
I will be glad to see my file in next release.
I just found that there is a way to change site priority.
So if someone looking for that.
MusicBee/Edit/Preferences/Tags (2)/
"auto-tagging" section, and then
Button with "..." on it at the end of lyrics text field.
After that just sort sites.
Last Edit: June 25, 2013, 07:04:59 PM by topol-m
Hmm, I'm not sure if this somehow relates to LyricsReloaded plugin.
topol-m
It is.
It show me "tekstovipjesama.com" in list. And that site for which I created file and put in "C:\Users\UserName\AppData\Roaming\MusicBee\mb_LyricsReloaded\providers" .
And list also contain all of those:
    http://rapgenius.com/
    http://www.plyrics.com/
    http://www.urbanlyrics.com/
    http://www.oldielyrics.com/
    http://www.tekstowo.pl/
    http://teksty.org/
    http://letras.mus.br/
    http://www.metrolyrics.com
    http://www.songlyrics.com/
plus few more.
Last Edit: June 25, 2013, 10:21:47 PM by topol-m
quick_wango
  • Software Engineer
Awesome! I should make a small website to distribute the community made providers
to save hijacking this topic i have moved the plugin loading issue to:
http://getmusicbee.com/forum/index.php?topic=10029.0
