THANK YOU SO MUCH FOR ADDING tekstowo.pl and teksty.org !!!
You implemented the request so fast! This plugin would be definitely one of the most popular ones.
Congratulations
However, I've just updated MB to the latest version available 2.1 (Pre2) and every time I'm searching for Lyrics it shows 'No lyrics found'.
I've checked quite a few popular Polish songs but the result is still the same - 'No lyrics found'.
I searched for the lyrics manually on tekstowo.pl and teksty.org (both services are enabled in MB/Preferences/Tags (2) as #3 and #4 lyrics source) and I can find all the lyrics there. Can someone else confirm this issue
For example, 'Ewa Farna - EWAkuacja', 'Jacek Kaczmarski - Lekcja historii klasycznej', 'Andrzej Rybinski - Nie licze godzin i lat' to name a few...
If I could help somehow, just let me know
I can run a debug or beta version if needed. Thanks
