Author Topic: Lots of IndexOutOfRangeExceptions  (Read 6283 times)
quick_wango
  • Software Engineer
I just looked into my error log and saw this:
http://dl.code-infection.de/ErrorLog.txt
Often they occur during sync with my gs3
could you post a screen shot of the 2 settings tabs for the device synnchronisation settings?
quick_wango
  • Software Engineer
here we go:
http://dl.code-infection.de/device-settings.png
http://dl.code-infection.de/sync-settings.png
For example when I first saw this I didn't have the converter activated.
This usually comes up shortly after I start the sync when when it already started copying the files (after reading in the device). Aborting and restarting the sync "fixes" it.
one other question - how do you initiate the synching?
eg. select files/ right click/ send to device or some other way?
and if so, do you send some files and then send some more?
quick_wango
  • Software Engineer
I left-click the device under devices and click on synchronise in the main view or right-click the device and click on the context menu entry
i have never had this issue myself but i can see how it could happen as there is potential issue with threads clashing. So could you try this version and let me know how it goes:
http://musicbee.niblseed.com/V2_1/MusicBee_Exe_Patched.zip
quick_wango
  • Software Engineer
I just did a sync and no error came up, however it didn't happen always so I'm not sure.
I think we can declare this as fixed until it shows up again, I'll keep using this patched build.
quick_wango
  • Software Engineer
