Author Topic: Export library as .odt or .ods file  (Read 2097 times)
tadatin
Customisationable export of fulll library records, or filtered by genre, artist etc to readable - .odt or .ods or .pdf format. Based on tags.
You can export tags with the help of 'Additional Tagging Tools' plugin, 'Library Reports' command to html, then reimport html to spreadsheet editor.
tadatin
Sorry, but for me it sounds a little bit too complicated.
Let me explain the situation.
I am a collector of Deep Purple live bootlegs. You can't buy it anywhere, it is an audience recording of live shows. You can find it anywhere: torrents, forums etc.
Now I have more than 200 shows. What's a problem? I can't remember which show I have. Having a document, created by MB itself is the best solution, but boroda's solution is a little bit complicated for me.
Also, I assume that for somebody having a list of all library can be useful as well.
