Author Topic: Resume radio streams on startup  (Read 16537 times)
@Steven, maybe i must delete this plugin from add-ons section of main site?
i agree - the developer hasnt been active for a long time
Boile
Hi Steven!
Please can you fix the problem with the plugin? It don’t work again!
Thanks!
3.4.7586
Hi Steven!
Steven has nothing to do with this plugin.
And as Steven said in his reply right before yours, the plugin developer hasn't been on the forum in quite some time. Actually the last time he was on the forum was in August 2015. That suggests that the plugin is no longer being supported. If the link is broken, you're out of luck. If the plugin doesn't work, you're out of luck.
