Hi Steven!
Please can you fix the problem with the plugin? It don’t work again!
Steven has nothing to do with this plugin.
And as Steven said in his reply right before yours, the plugin developer hasn't been on the forum in quite some time. Actually the last time he was on the forum was in August 2015. That suggests that the plugin is no longer being supported. If the link is broken, you're out of luck. If the plugin doesn't work, you're out of luck.
