Author Topic: Scamelon  (Read 30934 times)
Yeah, I've been having a heck of a time keeping a backup.  I'll do better.
Nice splash screen!
Notepad++ has been a huge help, too, thanks!
I finally managed to get a bit of a system down and find some time to look at this.  After messing with it for a few hours, I have much greater appreciation of your talents, Bee-liever.  It's a lot of work!
A couple of questions:
In general, does the order the elements are listed in the file matter?  It seems like after I rearranged a couple of things to try to make sense of what pieces go together, some things broke.
And one specific question, which for all I know may be related to the first.  I've almost got something cool going on here, but how do I get rid of that lingering pale blue line?  I can't figure out what's controlling it.
Yes, it matters. Sometimes I spend hours looking for what went wrong and finally find out the order of elements wasn't right.
Which one? Would you mark it with different color?
Good to know, thanks.  I can get the order sorted out with the dummy skin, I figure.
I'm talking about the line that's keeping the tab from blending with the toolbar.
Probably that's bdr value of Panel.Body.Default element.
That got it, thanks!
I'm stumped again.  How do I change the highlight color for the Refresh and Configure Layout buttons in the toolbar?  I can get the custom buttons the color I want, just not the built-in ones.  I have Panel.HeaderButtonOverride.Hightlight set, but that's not doing it.
  • MB Version: 3.6.8849 P
I don't think it's currently possible.  If I remember correctly, Panel.HeaderButtonOverride.Hightlight bg="" was proposed for this but hasn't been implemented yet.
NB. I can't find that thread, but I do recall it was this comment by Steven that triggered the discussion.
Last Edit: April 22, 2013, 07:39:08 AM by Bee-liever
SimonBRT
Funnily enough I have been struggling with the same thing for a skin mod i'm working on.  good to know, thanks Bee-liever!
Zokay, I'm stumped again.  How do I fill in the line between the "LibraryExplorer" header and the bar showing the categories?
Also, is it possible to skin that bar separately from the Playing Track panel, or are they always linked?
You can't. That's bg color of left navigator.
I don't think there are overrides for that. For overrides, look at this thread:
http://getmusicbee.com/forum/index.php?topic=2499.0
jistme
There are two lines, these determine them:
<element id="Panel.Body.Default" bg="255,0,0" fg="15,15,0" bdr="216,216,216" />
<element id="Panel.TabSelector.Default" bg="0,255,0" fg="75,75,75" bdr="0,0,255" />
As you can see used 1x red, 1x blue, 1x green for this example. This shows there is quite some 'sharing' going on:
Thanks.  It's the red lines just above and below the green that I want to get rid of, so I guess I'm screwed.  :)
Last Edit: April 24, 2013, 08:42:09 PM by scampbll
I'll ask here before submitting another request.  Is there any way to override this line under the tabs, which seems to be tied to bg on TabsBar.Tab.Highlight?  (Also, the similar line in Track Details tabs.)
I thought that's what TabsBar.JoinLine referred to, but I guess not. (Oh, it's directly above TabsBar.JoinLine.)
And what does TabsBar.DropCursor do, anyway?
Last Edit: April 26, 2013, 05:38:36 AM by scampbll
