Author Topic: Modern (A Metro Mod)  (Read 34381 times)
beeing good
Maleko12
Is there any way to make the toolbar thicker?
Marvin
Hey... Very cool. I like it :-)
You did a good job !
SimonBRT
Do you mean the main player bar?  If so, I believe this would mean changing all the source bitmap images, which is beyond my skills....
Maleko12
Sorry, I meant scrollbar. For me, I can barely tell where it is without close inspection.
SimonBRT
Yes, this can be done.  I'll have a look and try to post an alternate version...
Maleko12
SimonBRT
As requested, here is the version with the widened scrollbars.  Hope this is what you wanted, let me know if not..
Modern (alt scrollbars): http://www.mediafire.com/?vbl64kon7wo1v74
Last Edit: May 08, 2013, 07:23:29 PM by SimonBRT
Maleko12
I don't see any difference actually :/
SimonBRT
widened them further.  link in previous post updated...
Maleko12
OK, I definitely notice it now! Looks great. Thanks for doing this (twice)! Really appreciate it.
derausgewanderte
great, with broadened scroll bars now even better!
thank you
ma_t14
Excellent skin!
The only thing that in my opinion would make it better is to make the edges of the sidebars more prevalent (maybe a subtle grey color). They are white now and it seems like they are non existant which make it difficult to grab and move around.
Some of the text and icons would be better if they were a tad darker to improve readability.
Just my 2 cents otherwise I like this skin very much. Definitely a keeper  :)
tharpdaddy
Love the skin! Dumb question, how do i get my music player into the mode that's in the 3rd image?
SimonBRT
Thanks!  To set up as in the 3rd image just right click on the player bar (anywhere near the play buttons or progress bar for example) and then 'configure layout'/'display in top pane'.
