Thanks for the kind words guys!@derausgewanderte: to get the tabs as in the 3rd image open 'Preferences/Layout(1)/Main Panel/Tabs Orientation: Horizontal (Caption Bar)'. To put the player bar at the top of the screen just right-click on it and then 'Configure Layout/Display in Top Pane'.
I love too, version blue or green?
Loved the skin, just not a huge fan of the yellow selection bar (as in when clicking on items). Would it be possible for you to upload the xml or provide an xmlc with a grey selection bar? I would really appreciate that.
Quote from: Havokdan on April 29, 2013, 09:02:14 AMI love too, version blue or green?Do you mean just the selection bar highlight or the whole skin theme? I'm happy to change the highlights but changing the whole theme is probably more work than I will likely do. I can upload the sources however if you want to have a go yourself...
