Author Topic: "Show In Windows Explorer" in context menu  (Read 3377 times)
jeremymeyers
Hello-
I'm using MusicBee to go through and clean up my "incoming" music folder, and the ability to right click a file and open up its location in windows explorer would be great in order to go delete music i dont like, and reorganize and such.
jistme
That feature is already there.
If you right click a file, it's under 'Search' > 'Locate in Windows Explorer'
(I believe it was once suggested the word 'Search' might better be replaced by 'Find', which I agree on)
edit:
Found it ;-)  http://getmusicbee.com/forum/index.php?topic=8229.msg49095#msg49095
Last Edit: April 14, 2013, 09:16:43 PM by jistme
johnnyboy
You can also link that command and others to a toolbar icon.Really cool!
