Thanks Steven, this is a huge lifesaver for me. I DJ tango events, and being able to regulate the silence between songs is absolutely essentiel. I've been on the hunt for a new player to use for this purpose and with this change MusicBee becomes an option. Will this be included in future versions? Will there be bug fixes? I actually tried to use it last night with WASAPI, and the results were horrible. I need to be able to remove silence between tracks and add about 3 seconds of silence, so that it's consistently the same; with WASAPI, sometimes the silence was removed and sometimes it wasn't, sometimes the silence was added and sometimes it wasn't; and the beginning of each song was cut off. I'll test with Direct Sound tonight but I would love to see more support for this feature.
EDIT: I've been testing it a bit, it seems to work well with Direct Sound, but remove silence does not work at all. Some songs have 10 seconds of silence at the end and nothing happens.
