these are just getting better and better!
quick question: in your images in the opening post you do not have the track time displayed in the main player panel. it looks really nice and clean this way but i can't figure out how to not show the time/time remaining, can anyone help?
Thank you
About the track time, I guess that I haven't it displayed because of my DPIs.
You may try to modify the skin.xml file in the sources and the size of the track font to obtain the same view, but it's just a possible workaround, since from what I know there's no option to hide those elements.
Fantastic work!
These must be the cleanest skins around.
Also thanks for sharing the sources, I'm sure that might be very helpful to others.
A few remarks:
- Maybe the 'checkticks' would be nicer if also in blue?
- The borders between the preferences options are now 50,50,50. Maybe nicer with 255,255,255?
- The blue border around the caption bar is thicker than the panel border.
- The width of "TrackText' could be increased, especially on the right side. This is useful for long (often Classical) tracks.
- Did you leave out the 'Auto-DJ' icon in the player panel on purpose?
Thanks!
About the remarks:
1 and 2) Yes, I agree. Actually the blue skin is a copy of the charcoal one in which I swap all the "34,34,34" color values with a blue tint.
But since the skins are now near to completion, I can focus on them individually to enhance something here and there.
3) THIS is a serious issue. It looks well in the main panel, but it literally sucks when opening other windows. I don't know how to solve it! Help would be super appreciated!
4) Mmmm, I'll check it.
5) Fixed in v2 skins, not in v1 which are discontinued. But if you like v1 skins, you can simply play with the sources to build a custom solution.
