Author Topic: Sync button when player is connected  (Read 4671 times)
9cupsoftea
It would be nice if - when a player is connected - there is a more prominent sync button, perhaps on the main UI along the top or bottom.
Currently I use locked tabs with musicbee so to sync music (which I do often) I have to open a new tab, select my player from the side, and then click sync (then close tab again). Not sure if many others would like this, but I'd even take the ability to configure my own button to sync.
mikebo
A sync button would be alright if it was placed next to the device node. Placing it in the toolbar imho makes little sense.
Yeah, maybe it could go roughly where the inbox count is?
9cupsoftea
I have the node closed by default - just UI and album artwork. Though still, even in the node it would be preferable.
9cupsoftea
Sorry to bump my old topic, but I just wanted to add that it would also be cool to have a 'rip cd' button when looking at the cd drive node. Currently I have to go into menu, tools, rip cd, or use hot key (which sometimes don't work).
beeing good
You can set up a toolbar button for the rip cd command.
9cupsoftea
Yeah, I know. I don't really rip cds that often though that I wanta button always there for it. I just think if a context sensitive button can be added for syncing when a player is connected in the main ui, the same thing would be nice for ripping cds (and probably some other use cases too).
+1
similar to what I suggested here: http://getmusicbee.com/forum/index.php?topic=8657.0
