One of my albums is an .ape file as I just found out.
Never worked with one before, so I don't know how to deal with it.
I noticed that I can import it into MB, but it is treated there as 'one block' with 22 individual tracks which can NOT be edited individually.
It has all the titles correct, but some details should be changed.
And I like to split the block into separate tracks, to use them in my iPod later.
I already converted the .ape with Freemake converter into .mp3, but then it is still ONE block, which I need to split manually into 22 files.
And I loose all the (long) titles/details of this classical work.
Also came across Monkey Audio with similar result, just .wav instead of .mp3.
EDIT:
First I thought that a restart had solved the problem, it looked as if the whole block now were 22 properly named/tagged individual tracks.
I still cannot edit them one by one: if I select 1 track for editing, the whole block will be selected again.
Is there an easier way than converting the whole .ape (with Freemake into .mp3 or with Audio Monkey into .wav) and then sending everything to Audacity for manual splitting it up (and losing the track tags)?
