Hi all,
I'm sorry about not giving answer to your posts this week, it has been a busy week :-S
I've test the plugin in WinXP an Win7 and it's works as expected, so I've no clue about what's happening, so if you can tell me about your OS and config maybe I'll have a clue about what's happening...
In addition, I've built a "debug" release of the plugin that do the current behaviour:
- If the plugin is not able to remove the current file (give an exception), it writes the exception in a log at:
"C:\SendToRecycleBinPlugin.log"
So if you can run this plugin version:
https://dl.dropboxusercontent.com/u/63438/mb_SendToRecycleBin.zipand post the log that it's created, I will thank you very much.
Thank you very much for your patience
Regards,
Jorge
