Author Topic: In autoplaylists: Time <1m  (Read 2825 times)
beeing good
I'm trying to create a playlist of tracks I have listened to least but I want to filter out tracks that are less than 30 seconds long. There doesn't seem to be a way to do it, the Time field only accepts whole numbers, which must be minutes.
So could we have the ability to use numbers less than 1?
lnminente
Maybe its not what you are looking for, but it might help... Many of us use to rate intros, outros or really short songs with the bomb (no stars) for excluding them from autoplaylists, it is not automatic and requires some minutes to do it but it works :)
paq
Try this:
Time is less than 0:30
Worked fine for me :)
beeing good
My ratings are all over the place (think I tried to use the autorate thing in the Advanced Tagging plugin once) so this probably wouldn't be much help unless I went though everything and sorted them all out. I like the idea though...maybe one day I will start to rate tracks and use them for something  :D
Try this:
Haha ok I feel stupid now. I don't know why I didn't try ':', think I was just trying to use '.' - it works perfectly.
Thanks.
Last Edit: February 23, 2013, 12:51:14 AM by beeing good
