Author Topic: Option to start minimized, to put it at windows startup  (Read 3344 times)
There's a very simple way to do this yourself without Steven doing any programing.
Copy the MB executable file and drag it into your Startup folder.  Once there, right-click on it, select PROPERTIES, and towards the bottom you'll notice a field called RUN.   Use the drop-down to 'minimized.'
That should do the trick.
