Thanks a lot. That worked.
Is there a way to also remove th "up next" text and the red background?
I believe "up next" text was already gone.
For red background, if you want to change the color
search
and replace 79,24,22 with another color.
If you want to remove the red block, delete the following part.
<element name="#NextInfo" type="Block" xAnchor="Panel.Right" x="-280" yAnchor="Panel.Bottom" y="-74" width="280" height="53" bg="253,79,24,22" onDoubleClick="OpenNowPlayingAssistant"></element>
<element type="Line" xAnchor="Panel.Right" x="-280" yAnchor="Panel.Bottom" y="-75" width="280" height="1" bg="253,0,0,0"></element>
<element type="Line" xAnchor="Panel.Right" x="-280" yAnchor="Panel.Bottom" y="-21" width="280" height="1" bg="253,0,0,0"></element>
and search
widthDock="X:#NextInfo.Left" width="0"
replace it with
widthDock="X:Panel.Right" width="-280"
