Author Topic: Clear Look Dark Skin [Updated, there was a problem with theatermodes]  (Read 11172 times)
Greb
INSTRUCTIONS
[1] Download the file:   http://filebeam.com/78ccf765887784096ee7988283b3b4a9
[2] Unzip it in the MusicBee root folder.
The zip file contains both the skin and a few theater modes specific for this skin.
PS Aditional theater mode not included in the previous zip file: http://filebeam.com/667541b48bb5c2f12e487f8a1558b0a0
IMAGES (ThearterModes in the images are included in the zip file)
Last Edit: February 13, 2013, 05:50:51 AM by Greb
beeing good
lnminente
Greb
beeing good
One thing I've noticed is that the colour square around the artwork in Artwork View (not compact) is pretty much the same colour as the background so you can't see what you have selected.
Greb
No way to help it. I have made the skin the way that when you select some trakcs, it only changes letters colour [not background colour]. The only way to do so is to change the selected background colour, though this way selecting in album&tracks looks uglier...
beeing good
NickPE
The skin looks great, thanks.
I'm having a problem though. It seems that I have a lot of differences although I followed your instructions (nothing complex there). I'm seeing the default player bar for example instead of the skin's and also I see other minor details as well.
I'm probably missing something so any ideas?
I'm running the latest beta in windows 8.
NickPE
