Author Topic: Ability to move across drive letters  (Read 2244 times)
worldcoast
I've got a large network store on my Z drive which is where I store all of my music, but I store my downloads to my D drive which is local.
It'd be nice to be able to consolodate all locations to one and filter duplicates.
donjulien
+1
I store new music on a folder on my desktop (c:) which goes to MusicBee's Inbox. I clean up the tags and then would like the clean files to go to the "My Music" foler on d:, and stay in the library (out of Inbox).
BTW, great work! Media Monkey and J River are almost completely out of my system.
In the COMPUTER section of the left-side panel select the source drive\folder.  In the main panel highlight the files to be moved - either by CONTROL-CLICKing individual files, or clicking on the top file and then SHIFT-CLICKing on the bottom file.  (Regular Windows convention here.)  Then left-click drag the files to the new drive\folder.  That should move them.
Check out the MusicBee Wiki.
donjulien
Phred:
Hey! It works! Thank you.
Still, I don't get the limitation of "do not reorganize across drives". Good to know there is a way around it (within MB, that is)
in the next update you can drag the files from the inbox across disks now as well
