Author Topic: Any idea why Rescan won't import my M3U playlists?  (Read 10465 times)
chrisjj
My initial scan of folders including .M3Us gave no playlist on the media tree. I added some more .M3Us and rescanned - again none were added. MB said "no new files found". MB File, Open file or URL works fine on these .M3Us.
Here's a sample:
#EXTM3U
#EXTINF:183, Francisco Canaro (Quinteto Don Pancho) - Viento en popa
08427328130905\1\1.wma
#EXTINF:149, Francisco Canaro (Quinteto Don Pancho) - Champagne tango
08427328130905\1\6.wma
and from a sub-folder:
#EXTM3U
..\08427328130905\1\1.wma
..\08427328130905\1\6.wma
This on MB 2.,0 Final, Win 7 Pro 64-bit.
When you open the dialog using File > Rescan/Add Files, is "include playlists" checked?
Well, I'm no help then.  :)  Hopefully someone else will have an idea.
it appears the code for adding a playlist was removed for v2.0
edit:
actually it is importing the playlists but simply not refreshing the left sidebar. If you press F5 afterwards or restart does the playlist appear?
it wont import the files in the playlist to the library for some scenarios so i will fix that
Last Edit: January 29, 2013, 09:28:31 PM by Steven
chrisjj
No.
These tracks are already imported into the library.
If anyone has succeeded in getting 2.0 Final Rescan to add a .M3U to the library, I would be gratfeul to know.
chrisjj
Anyone? Thanks.
egret17
edit:
Any idea when a fix will be available for this? I've tried the suggestions in this thread and my m3u playlists still will not import. Thanks.
gpzbc
I know this was supposed to be fixed, but I can't seem to get it to import playlists either.   File > Rescan/Add Files with "include playlists" checked does not work for me.  The only way I can do it is to open the m3u file and then save the Now Playing List to a playlist.  Am I missing something?  Thanks so much.
EDIT:  I got it to work. The only way to import an m3u playlist into MB was to change the default Playlist type in MB Library settings to m3u in order for MB to import it.  (see http://getmusicbee.com/forum/index.php?topic=13011.msg86224#msg86224)
And for what it is worth, I still had to hit F5 to get it to show up in the left sidebar.  Seems like it might still be a bug?
Last Edit: December 09, 2014, 06:42:04 AM by gpzbc
chrisjj
I.e. http://i.imgur.com/1wIlrKG.png . Thanks! Worked fine here.
FWIW, no such problem here on V2.4.5404.
BTW, anyone wanting a conventional menu bar can get it thus: http://i.imgur.com/vx3EKpG.png
gpzbc
Thanks for the picture.  That will be helpful to the next dummy like me.  ;)
Weird. I'm running 2.5.5447.  I wonder if it is a regression?
chrisjj
FWIW, note that your version is ahead of the one current (today) on http://www.getmusicbee.com/download/ .See http://www.getmusicbee.com/release_notes.html .
And FWIW, I am running the Portable Application.
gpzbc
@chrisjj-
The latest patch version is always available here:  http://musicbee.wikia.com/wiki/Latest_Update
Steven often updates with new features and fixes and sometimes there are three or four new patches issued in a week.
chrisjj
Thanks. I'm conservative and prefer to minimise frequency of updates by sticking with the current releases.
