Author Topic: Sort in Multiple Columns  (Read 31602 times)
maleko12, i'll still do what you suggest for the next version but just to let you know i added a 4th order sort in the preferences as i noticed you use 4: artist, year, album & disc-track no
http://www.mediafire.com/?gotrkclzdj2
this is the same release as the one that fixes the equliser problem mentioned in the downloads/patches section
Last Edit: February 26, 2009, 11:01:21 PM by Steven
Maleko12
o nice! ;D thanks for this update Steven and I can't wait for the next version.
chorpo
This was implemented in 0.3 version and it seems that it is solved. Runs and looks good...
Multiple column sorting  works great.
Try CTRL+ column header people. Steven rocks as usual ;)
peter
Maleko12
