I'm using the most recent build of MusicBee plus a Logitech G13 and their LGS 9.02.65 software. I made sure to install the required dependencies.
The plugin is in MusicBee's plugin panel and when I check the config on it, it doesn't see any Logitech device. I try to save the config and get the below message which makes sense since it can't see the G13. I'm on Windows 11 Pro if that matters...
Any help appreciated... I got the android remote working and the XBL Gamebar plugins, so this one isn't as critical, but with my G13 always on, it would be a "nice to have". TIA
MusicBee v3.4.8033.18564D (Win10.0), 1 Jul 2022 23:32:
at MusicBeePlugin.Plugin.openScreens()
at MusicBeePlugin.Plugin.settingsChanged()
at MusicBeePlugin.Settings.saveButton_Click(Object sender, EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventArgs mevent)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
