http://musicbee.niblseed.com/Weekly/MusicBee_2_1_4770.zipbackup:
http://www.mediafire.com/?l4u7j83y73caeeithis is an incremental update and includes all changes since 2.0 - unzip and copy all files to your MusicBee program folder
- the right sidebar now auto-opens when collapsed and the mouse is hovered on the right edge of MusicBee (like it currently does with the left panel)
- MusicBee now remembers the active filter and scrollbar position when returning to a node in the left navigator panel
- there are now 16 custom tags and 16 virtual tags available
- the custom search function (click the search button in the top right main panel) has been improved so all the fields used in the last search are remembered and can easily be edited as a new custom search
- you can now view which playlists a track is included on and jump to the playlist - right click on a single file/ Search.../ Locate in Playlist
- you can replace files (eg. with higher quality versions) from the right click menu - right click/ Send To/ Folder(Replace)/ Replace the Selected File
- the Artwork layout now allows the Album count to be not displayed when grouping by Artist saving vertical space - the album count will only display inside the artist picture when hovering over the picture
- the A-Z jump-bar can be configured to display vertically - set in Preferences/ Layout
- left navigator panel picture can now be set from the Preferences/ Layout dialog
- the layout configuration options for the Now Playing panel have all been consolidated into the Panel Customisation dialog
- new option to disable prompting when using the permanent delete key (SHIFT delete) - set in the main Preferences panel
- "Track and Artist" panel is renamed to "Playing Track" panel
- now playing notification popup can now be configured to show the current track position
- the Track Browser can now be configured to show vertically side by side - set in Preferences/ Layout
- auto-shutdown can now be configured to just stop playback
- the Podcasts panel now has 2 filtering options available from the layout button (on the left the search box)
- Exclude listened tracks
- Exclude tracks not downloaded yet
- MTP mode device synch enhanced to support .M3U playlists and folder.jpg artwork - set in the device preferences panel
- a number of enhancements for the Theatre Mode plugin that is required by some of the newer skins
- a lot of bugs fixed
translator file - updated new.txt file (this file is only used by translators and not required for the MusicBee application update):
http://www.mediafire.com/view/?t9r5p7bv5mk84qvnote anyone who is using windows 8 and experiencing random crashes, please send me a PM as there is a possible workaround
