Author Topic: UPNP  (Read 139087 times)
use the link from the first post in the UPnP plugin topic
wwulff
I've just started using MusicBee due to the new UPnP capability and am impressed by the general function and features of the software as a whole, so I'd love to get this plugin working fully for me. Now I'm not sure if its a set-up issue or perhaps a bug, but I'm having a few issues trying to get this to work with a Stream Magic 6.
The issue occurs whenever the GetEncodedFile method is invoked. The SM6 will play the first couple of seconds of audio which then cuts out. The track timer on the SM6 continues to increase as if data is being received, and the track continues to play until the end in MB. The output works perfectly fine when the mp3 file is encoded with LAME and the GetFile method is used instead, but whenever the source file is encoded with anything other than stored Lame it runs into trouble.
I can push the same problematic tracks from a NAS using a combination of BubbleUPnP, and Plex to the SM6 without issue, but its not really a like for like comparison.
Here is the log and the config settings: http://we.tl/nkoHO2s6K3.
The first track plays though fine, the second track stumbles and fails until stopped in MB.
Any help greatly appreciated!
v. 2.5.5478
did you try using the default of encoding to PCM?
There is some seeking restrictions when encoding to MP3 that the device might not handle
wwulff
Hi Steven, thanks for getting back so soon.
I've tried with all the options and the closest I seem to get is using mp3 (with lame encoding), i.e. it starts to play sound on the SM6, albeit for a couple of seconds.  If I stop the track after a couple of minutes of silent playing in MB, the SM6 display updates the track to stopped but I don't think MB is quiting the task fully. I'm only guessing at that as if I then exit the program, I also have to forcibly close the application process via task manager which also closes lame.exe also left open.
I've retested each of the encoding options and attached the logs for each option. Weirdly (or not) the useragent value is populated using PCM 16. For AAC and OGG a different error is reported about the startIndex parameter.
Happy to be a guinea pig for the device if needs be and hope I'm using the correct plugin version!
I think you may be onto something with the seeking, I've not tried seeking a playing track with BubbleUPnP until now. BubbleUPnP tries the seek request but displays 'Internal Error (code: 400)' and continues to play the track from where it is up to (with SM6 also continuing to play the track).
Log files: http://we.tl/2TyevyG8sD
plc
Since discovering MusicBee around a fortnight ago, I just want to say how much I really like (a) the software in general, and (b) the DNLA functionality - it communicates with my Neet AirStream (hi-fi dongle to allow music to be streamed from laptops, phones & tablets via wi-fi) really well.  I suffer the odd drop-out occasionally but I'm convinced that has more to do with the location of the AirStream in relation to my wi-fi router than anything to do with MusicBee.
I'm wondering if there's any way of being able to easily change the output device (e.g. from AirStream to my telly or computer) from the home screen without needing to go through Options - Player - Output ?
Welcome to the forum,
If you update MusicBee to the latest beta version, you will find the new option 'Output To' when right-clicking a track.
http://getmusicbee.com/forum/index.php?topic=13648.msg88157#msg88157
Last Edit: January 15, 2015, 01:50:36 PM by hiccup
plc
Many Thanks, hiccup.
Does that change the default 'Output' setting so that all music from thereafter is output to that device - or is that just to override the selected track?
Since on my particular system UPNP plugin is not working very well I'm not sure on the exact behaviour,
but I would assume this should only stick for the selected track and possible queued tracks.
To have the output setting changed globally by means of some shortcut, there will have to be posted a wish for that in the wish list topic.
Ben6363
Hello
I installed the plugin and now I got the message "device 'denon avr-x 1100w' is not ready for output", I have no Idea what I can do.
I try what I found on this forum, google leads me to this. But it still dosen't work.
Sorry for my bad english.
Cam you please help me?
Does that help?:
703341; 1 RestartServer - Der Typeninitialisierer für "AudioEncoder" hat eine Ausnahme verursacht.
744636; 2 RestartServer - Der Typeninitialisierer für "AudioEncoder" hat eine Ausnahme verursacht.
3; 1 Initialise - 17.01.2015 23:12:32
68; 2 GetNetworkAddresses - 192.168.178.24,dns=True,name=Drahtlosnetzwerkverbindung,speed=65000000
70; 3 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
73; 4 GetNetworkAddresses - http://192.168.178.24:49382
756; 5 ProcessMessage 192.168.178.31 - device 'uuid:5f9ec1b3-ff59-19bb-8530-0005cd49925c:Denon AVR-X1100W',valid=True
764; 6 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
769; 7 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
776; 8 Activate:True - Der Typeninitialisierer für "AudioEncoder" hat eine Ausnahme verursacht.
29217; 9 ProcessMessage 192.168.178.24 - device 'uuid:5a91605b-c53c-4778-9410-aca73eb5e32d:MediaMonkey Player',valid=True
29218; 10 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
29220; 11 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
29222; 12 Activate:True - Der Typeninitialisierer für "AudioEncoder" hat eine Ausnahme verursacht.
29403; 13 ProcessMessage 127.0.0.1 - device 'uuid:5a91605b-c53c-4778-9410-aca73eb5e32d:MediaMonkey Player' disconnected
29403; 14 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
29403; 15 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
29404; 16 Activate:True - Der Typeninitialisierer für "AudioEncoder" hat eine Ausnahme verursacht.
29445; 17 ProcessMessage 127.0.0.1 - device 'uuid:5a91605b-c53c-4778-9410-aca73eb5e32d:MediaMonkey Player',valid=True
29446; 18 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
29446; 19 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
29636; 21 Profile - Generic Device, useragent=
118386; 22 RestartServer - Der Typeninitialisierer für "AudioEncoder" hat eine Ausnahme verursacht.
253188; 23 Profile - Generic Device, useragent=FDSSDP
254956; 24 Profile - Generic Device, useragent=FDSSDP
258066; 25 Profile - Generic Device, useragent=FDSSDP
262135; 26 Profile - Generic Device, useragent=FDSSDP
421576; 27 RestartServer - Der Typeninitialisierer für "AudioEncoder" hat eine Ausnahme verursacht.
4; 1 Initialise - 17.01.2015 23:22:31
66; 2 GetNetworkAddresses - 192.168.178.24,dns=True,name=Drahtlosnetzwerkverbindung,speed=65000000
69; 3 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
72; 4 GetNetworkAddresses - http://192.168.178.24:49382
100; 5 ProcessMessage 192.168.178.24 - device 'uuid:5a91605b-c53c-4778-9410-aca73eb5e32d:MediaMonkey Player',valid=True
341; 6 ProcessMessage 192.168.178.31 - device 'uuid:5f9ec1b3-ff59-19bb-8530-0005cd49925c:Denon AVR-X1100W',valid=True
349; 7 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
350; 8 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
354; 9 Activate:True - Der Typeninitialisierer für "AudioEncoder" hat eine Ausnahme verursacht.
1913; 10 Profile - Generic Device, useragent=
185554; 11 Profile - Windows Media Player, useragent=Microsoft-Windows/6.1 UPnP/1.0 Windows-Media-Player-DMS/12.0.7601.17514 DLNADOC/1.50
4; 1 Initialise - 17.01.2015 23:32:12
71; 3 GetNetworkAddresses - 127.0.0.1,dns=False,name=Loopback Pseudo-Interface 1,speed=1073741824
103; 5 ProcessMessage 192.168.178.24 - device 'uuid:5a91605b-c53c-4778-9410-aca73eb5e32d:MediaMonkey Player',valid=True
408; 6 ProcessMessage 192.168.178.31 - device 'uuid:5f9ec1b3-ff59-19bb-8530-0005cd49925c:Denon AVR-X1100W',valid=True
415; 7 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
419; 8 Profile - Generic Device, useragent=AV SURROUND RECEIVER|
425; 9 Activate:True - Der Typeninitialisierer für "AudioEncoder" hat eine Ausnahme verursacht.
1912; 10 Profile - Generic Device, useragent=
Last Edit: January 17, 2015, 10:37:46 PM by Ben6363
poictesme
Denon receivers have a chequered history when it comes to network functionalities.
Now, this probably does not apply to you case but I thought I should warn you.
I own a Denon and although I am very happy with the way it sounds, I had to unplug
it from my lan and I am now flawlessly streaming MB to a Pi running Kodi.
One thing you could try is to turn the Denon's dhcp on and off, and check that your firewall
isn't blocking whatever ports MB is using for streaming.
Julien
Hi
I don't know what I'm doing wrong or just not doing, but I'm not able to stream to a blu ray player or a home cinema system. It seems that it's trying to start playing but then skips to the next track and so on until the next track and the device I'm sending the file to displays a message with something like file corrupted or not supported. It's strange that I'm also using jriver on the same devices and works flawlessly.
Here's the log>
242405; 454 GetEncodedFile[96] - exit=10004, playtime=163102
252498; 455 Play - D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# (http://192.168.1.2:49382/encode/407AA59B91EA3B28-2147483216.wav)
252518; 456 Profile - Generic Device, useragent=
252519; 457 Profile - Generic Device, useragent=
252520; 458 GetEncodedFile[97] 192.168.1.2 - HEAD D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
253420; 459 StateTimer - Loading,old=Stopped
254023; 460 Profile - Generic Device, useragent=
254023; 461 Profile - Generic Device, useragent=
254025; 462 GetEncodedFile[98] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
254026; 463 GetEncodedFile[98] - exit=0, playtime=1
254243; 464 Profile - Generic Device, useragent=
254244; 465 Profile - Generic Device, useragent=
254245; 466 GetEncodedFile[99] 192.168.1.2 - HEAD D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
254413; 467 Profile - Generic Device, useragent=
254416; 468 Profile - Generic Device, useragent=
254417; 469 GetEncodedFile[100] - npt=0.000-0.000
254419; 470 GetEncodedFile[100] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
254426; 471 GetEncodedFile[100] - exit=10054, playtime=6
254435; 472 Profile - Generic Device, useragent=
254438; 473 Profile - Generic Device, useragent=
254439; 474 GetEncodedFile[101] - npt=0.000-0.000
254440; 475 GetEncodedFile[101] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
254458; 476 GetEncodedFile[101] - exit=10054, playtime=17
254563; 477 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254563; 478 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254565; 479 GetEncodedFile[102] 192.168.1.2 - HEAD D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
254675; 480 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254678; 481 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254679; 482 GetEncodedFile[103] - npt=0.000-0.000
254680; 483 GetEncodedFile[103] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
254691; 484 GetEncodedFile[103] - exit=10054, playtime=10
254697; 485 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254700; 486 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254702; 487 GetEncodedFile[104] - npt=0.000-0.000
254703; 488 GetEncodedFile[104] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
254720; 489 GetEncodedFile[104] - exit=10054, playtime=15
254728; 490 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254731; 491 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254732; 492 GetEncodedFile[105] - npt=40.000-0.000
254733; 493 GetEncodedFile[105] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
254777; 494 GetEncodedFile[105] - exit=10054, playtime=42
254881; 495 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254882; 496 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254884; 497 GetEncodedFile[106] 192.168.1.2 - HEAD D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
254894; 498 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254897; 499 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254899; 500 GetEncodedFile[107] - npt=0.000-0.000
254901; 501 GetEncodedFile[107] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
254914; 502 GetEncodedFile[107] - exit=10054, playtime=11
254917; 503 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254920; 504 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254922; 505 GetEncodedFile[108] - npt=0.000-0.000
254923; 506 GetEncodedFile[108] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
254944; 507 GetEncodedFile[108] - exit=10054, playtime=19
254957; 508 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254960; 509 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
254961; 510 GetEncodedFile[109] - npt=40.000-0.000
254962; 511 GetEncodedFile[109] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#1# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
255345; 512 StateTimer - Stopped,old=Loading
255367; 513 Play - D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#2# (http://192.168.1.2:49382/encode/407AA63891EA3A8B-2147483158.wav)
255390; 514 Profile - Generic Device, useragent=
255391; 515 Profile - Generic Device, useragent=
255392; 516 GetEncodedFile[110] 192.168.1.2 - HEAD D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#2# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
257151; 517 PostSoapRequest - 500,send=POST /upnp/control/AVTransport HTTP/1.1
Host: 192.168.1.5:52323
User-Agent: MusicBee UPnP Plugin
Content-Type: text/xml; charset="utf-8"
SOAPAction: "urn:schemas-upnp-org:service:AVTransport:1#Play"
Content-Length: 304
<?xml version="1.0" encoding="UTF-8"?><s:Envelope s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:s="http://schemas.xmlsoap.org/soap/envelope/"><s:Body><u:Play xmlns:u="urn:schemas-upnp-org:service:AVTransport:1"><InstanceID>0</InstanceID><Speed>1</Speed></u:Play></s:Body></s:Envelope>
257152; 518 SoapRequest:Play:urn:schemas-upnp-org:service:AVTransport:1:InstanceID=0,Speed=1 - <?xml version="1.0"?><s:Envelope xmlns:s="http://schemas.xmlsoap.org/soap/envelope/" s:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/"><s:Body><s:Fault><faultcode>s:Client</faultcode><faultstring>UPnPError</faultstring><detail><UPnPError xmlns="urn:schemas-upnp-org:control-1-0"><errorCode>501</errorCode><errorDescription>Action Play failed
</errorDescription></UPnPError></detail></s:Fault></s:Body></s:Envelope>
257153; 519 Play - status=500,url=http://192.168.1.2:49382/encode/407AA63891EA3A8B-2147483158.wav
257198; 520 Play - D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# (http://192.168.1.2:49382/encode/407AA5D991EA3AEA-2147483153.wav)
257215; 521 Profile - Generic Device, useragent=
257216; 522 Profile - Generic Device, useragent=
257218; 523 GetEncodedFile[111] 192.168.1.2 - HEAD D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
258141; 524 StateTimer - Loading,old=Stopped
258345; 525 Profile - Generic Device, useragent=
258346; 526 Profile - Generic Device, useragent=
258348; 527 GetEncodedFile[112] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
258349; 528 GetEncodedFile[112] - exit=0, playtime=0
258575; 529 Profile - Generic Device, useragent=
258578; 530 Profile - Generic Device, useragent=
258579; 531 GetEncodedFile[113] 192.168.1.2 - HEAD D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
258689; 532 Profile - Generic Device, useragent=
258693; 533 Profile - Generic Device, useragent=
258694; 534 GetEncodedFile[114] - npt=0.000-0.000
258695; 535 GetEncodedFile[114] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
258704; 536 GetEncodedFile[114] - exit=10054, playtime=6
258711; 537 Profile - Generic Device, useragent=
258715; 538 Profile - Generic Device, useragent=
258716; 539 GetEncodedFile[115] - npt=0.000-0.000
258718; 540 GetEncodedFile[115] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
258751; 541 GetEncodedFile[115] - exit=10054, playtime=31
258848; 542 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
258850; 543 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
258851; 544 GetEncodedFile[116] 192.168.1.2 - HEAD D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
258963; 545 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
258966; 546 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
258968; 547 GetEncodedFile[117] - npt=0.000-0.000
258970; 548 GetEncodedFile[117] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
258983; 549 GetEncodedFile[117] - exit=10054, playtime=11
258986; 550 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
258989; 551 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
258990; 552 GetEncodedFile[118] - npt=0.000-0.000
258992; 553 GetEncodedFile[118] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
259010; 554 GetEncodedFile[118] - exit=10054, playtime=15
259015; 555 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
259019; 556 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
259021; 557 GetEncodedFile[119] - npt=40.000-0.000
259023; 558 GetEncodedFile[119] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
259077; 559 GetEncodedFile[119] - exit=10054, playtime=52
259179; 560 GetEncodedFile[109] - exit=10054, playtime=4214
259182; 561 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
259184; 562 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
259185; 563 GetEncodedFile[120] 192.168.1.2 - HEAD D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
259194; 564 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
259198; 565 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
259199; 566 GetEncodedFile[121] - npt=0.000-0.000
259200; 567 GetEncodedFile[121] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
259213; 568 GetEncodedFile[121] - exit=10054, playtime=11
259215; 569 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
259219; 570 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
259220; 571 GetEncodedFile[122] - npt=0.000-0.000
259222; 572 GetEncodedFile[122] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
259233; 573 GetEncodedFile[122] - exit=10054, playtime=9
259241; 574 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
259245; 575 Profile - Generic Device, useragent=UPnP/1.0 DLNADOC/1.50
259246; 576 GetEncodedFile[123] - npt=40.000-0.000
259248; 577 GetEncodedFile[123] 192.168.1.2 - GET D:\Music\Therion-Theli (2014 Reissue)-2014\Therion - Theli (2014 Reissue).flac#3# to 192.168.1.5; mime=audio/wav,rate=44100,channels=2
Thank you!
DoS
Hello, I switched from Foobar2000 to MusicBee (winamp in the early days). MusicBee can do everything I needed of Foobar2000, except one feature:
UPNP Local Render Server.
I'm using BubbleUPNP with AudioCast and want to play music with my music player on android smartphone on my computer monitors via musicbee. It would be nice, if the UPNP Plugin could be accordingly extended,
DoS
cb154
I am new to MB and liking it already. However I am having a small issue with the uPnP. I have it working on my phone using myaudiostram app (iOS) and that is great. However if i restart the app on my phone I can no longer see my MB library. I can make it reappear simply by making a change to one of the settings in the uPnP plugin (such as name) then all is well again. Is anyone else suffering the same issue ?
Think it also worth noting that if i run music bee on my old windows 7 box this does not happen. it only happens on my windows 10 box.
