Update audio stream only while preserving all kinds of metadataMB allows you to replace your music file with another while preserving all tags and metadata of the original including date added, play count, rating, and (auto-)playlists. This feature can be useful when you want to update your music file to better quality or format without altering any metadata of the original.
1. You can choose either a target file (to be replaced) or a source file (to replace with). There's no need to tag the source file before.
2. Right click on the track, select Send To> Folder (Replace)> and choose one of the two replace commands
3. Choose a target or source file with the file browser, and click on "OK" button of confirmation dialog. Now MB will take care of the rest.
4. Note that the target file will change to the source file's file format. For example, if you replace an MP3 file with a FLAC file, the replaced file will be a FLAC file.
Caution: MB will delete the source file afterwards. If you want to keep the file, restore it immediately from Recycle Bin, or make a copy of it before using it for this purpose.
