Author Topic: Bee78 "retro" skin  (Read 69405 times)
grottig
Thank you Bee-liever,
you don't know how happy I am with this skin - it's made for eternity!  :)
https://picload.org/view/dadiiill/be78.jpg.html
Last Edit: February 24, 2018, 09:21:12 AM by grottig
john wim
New here. I just make a mod from the source files from old Bee78 skin, but I want to add the progress bar feature from the latest Bee78 skin, I was working on that, but tbh, I had no clue. Can you help me on how the code and images can be?
It's a new feature supported from v.3.1
See "track text over progress bar for bitmap skins" part in the middle: https://getmusicbee.com/forum/index.php?topic=21851.0
john wim
Thanks for the advice, got it to work after a couple of tries, thanks.
hbenthow
At least on my computer, there's a weird annoyance in the latest version of the Bee78 skin. Whenever I skip forward or backward in a track with the mouse pointer on the progress bar, it never skips to the place that I click on. Instead, it always skips nearly a centimeter to the left of where I click. This doesn't happen in any other skin (even the older versions of Bee78).
Does anyone know what could be causing this, and how to fix it?
  • MB Version: 3.6.8849 P
It's the result of how I overcame a problem with using .svg images for the progress bar infill.
I'm currently trying to fix this for the 3.2 final release.
Really like what you've done!  :)
Please consider publishing this as a new skin.
hbenthow
Does this mean that if you fix the problem in time, the fixed version of Bee78 will automatically be included with the next MusicBee update?
Yes  :)
edit:
not in the patches.  usually in the full installer updates.
Last Edit: June 21, 2018, 11:45:35 PM by Bee-liever
hbenthow
I usually just automatically update through the patches. Would I have to manually install the new version of Bee78?
Patches don't contain any skins. You'd have to either download 3.2 when it goes final or simply download the skin when it's fixed. Either way is painless. Download 3.2 and just install over your existing installation. Or just install the fixed skin over the old one.
hbenthow
I installed MusicBee through the Windows Store, so I'm not sure if I can perform a full reinstall without losing my settings.
I have updated this skin for MB 3.2 testing.
My understanding is that Steven will release a 3.2 Windows Store version when 3.2 is in final release.
test-_-bot
Yes, this skin is the most pleasing of all the skins I tried, and I have used MB for years.  The retro/art-deco look is very cool, and colors are just so darn ideal.  Very good work, and thank you.
stardepp
Since the last MusicBee update there is now a stop button for standard skins.
Will there be a stop button for the Skin Bee78? That would be great.
