Author Topic: 'comments' field under detail view  (Read 4237 times)
hughlilly
It'd be cool to somehow have the "comments" tag available under display fields...
Debby747
Instead of adding a new line to the 'Player Control Panel' which would add screen waste,
perhaps the display could alternate between 'Now Playing' and 'Comments' -
if comments are present.
Although I have sometimes comments fields tagged, most of the time I don't.
Greetings
D.
hughlilly
you can already acheieve that
from the Layout preferences, or using the drop-down by the details panel header, choose Configure Panel Layout
and just add <Comment> to one of the display fields. You can wrap it over multiple lines if you want using the row span setting
I do realise now i'm no longer showing the field selector button in this panel so i will add that back in, but <Comment> represents the comments field
hughlilly
Oh great, thanks! I swear I'd already tried that, maybe not with an uppercase C though.
the field selector has been restored in the latest 1.2 beta
