Author Topic: seperated sort options for each playlist  (Read 3700 times)
9ido
hello,
here's one i would love to see incorporated in a new version of musicbee: a sort option that gets memorized for each playlist. like in itunes. right now, if i have one playlist that's sorted by album, and another that sorted by #, i have to correct the sorting every single time that i go to a different playlist, because the preference is global to all playlists. i hope this can be fixed, that would be great.
all the best,
9ido.
it should already do that for auto-playlists. To acheive the same for standard playlists, right click on the playlist/ Edit Playlist
and tick "custom fields for this playlist only" in the displayed fields section
9ido
ah, thank you.
but, could this then be set to either standard behaviour, or optional standard behaviour? i like to set sorting individually for each playlist that i create (and that is a lot of them,) and i think that would make sense.
best,
9ido.
HHM
+1 for making it optional standard behaviour.
right now the function is hidden too well:)
Last Edit: October 03, 2012, 08:18:04 PM by HHM
