Author Topic: (Fixed) Minor Skinning Bugs  (Read 9152 times)
  • MB Version: 3.6.8849 P
Standard Skins
1.)   If using <element id="MusicLibraryInTab"> when MB first loads, the standard "MusicLibrary" image is displayed in the panel header
If you switch tabs and then back to Music tab correct image from "MusicLibraryInTab" is shown.
If you navigate from within the tab and then use the back arrows, it reverts to the main "MusicLibrary" image again
Dependent Skins
2.)    <element id="Menu.CommandButton.Selected" /> is not being picked up only for close button on edit panel
Correct Colour
Incorrect Colour
3.)   <element id="Panel.StatusBarControl.Default" /> not changing in dependent skins.  Won't change even if undefined in parent skin (uses default skin grey)
<element id="Panel.StatusBarControl.Highlight" /> works fine
Last Edit: October 28, 2012, 03:03:09 AM by Bee-liever
Hello-ello-llo-lo-o?
Is anyone there-here-ere-re-e?
the 3 issues should be fixed now for the next update (v2.1)
i have changed it so the location bar always reflects the icon on the left navigator, and if "MusicLibraryInTab" is set, that only affects the icon in the tab
Thank you
