Author Topic: Lock-down option for theatre mode would be nice  (Read 2269 times)
weare
same as the existing option to run visualiser in lock-down mode
Last Edit: September 22, 2012, 05:43:01 AM by weare
i dont understand what you mean.
if you are refering to being able to open a theatre mode view when in locked down mode, you already can from the View menu
otherwise you will need to explain some more what you mean
weare
sorry, my bad english - what I mean is I can run the visualiser and then select 'main player (lock-down mode)', but I cannot run theatre mode and then select 'main player (lock-down mode)
thank you, found it, I didn't try hard enough
Last Edit: September 22, 2012, 09:28:48 AM by weare
