Author Topic: More control over folders in Computer tree  (Read 2629 times)
john6555
It would be nice to have the ability to delete/create/rename folders in the Computer tree (in the left pane) and a context shortcut to open the selected folder's path in Windows Explorer.
you can already rename and delete folders in the computer section using right click (although i do have a restrction on folder deletion that the folder must be empty), and move folder using drag-drop action.
you can open in windows explorer by right clicking a file > Locate in windows explorer
john6555
Oops, I missed that! I guess you could add "Locate in Windows Explorer" to the folder context menu too, unless you think its a waste of time.
How about adding the option to scan folders recursively in the Computer section? So you could select a top level folder and work on multiple sub folders at once if desired.
