I have been working on this skin, but i have a problem with the the hi and lo versions of skins showing through each other and just staying there.
Like the lines for the others should be as thin as the 'X' but they are as thick as you can see, because i either used them or hoovered over them. I created those icons myself, so maybe i did something wrong. Each version is on an invisible background.
As you can see, the maximize button is showing what appears to be a mixture of itself and the restore button.
Also, the highlight effect on these are delayed.. in that, if i pass the mouse over an item, it highlights as it should, but takes a while after i move the mouse away for it to go back to dim.
Any ideas?
