Hi kelsos,
I would like to use the remote, but I can't get it to work. I have the newest MusicBee, MusicBee Remote pluging and the newest MusicBee Remote App. I have a normal Windows 7 machine and a Nexus 4 with the standard Android 4.3 rom.
The problem is; I can't connect my pc and the phone. Not by scanning and not by adding it manually. I had some problems with connecting apps to my pc in the past, because of the Eset firewall (I should whitelists some ports, but I'm too lazy
), but even when I switch the firewall off, I still can't connect...
What am I doing wrong?
Although I haven't used it yet, I have a small improvement for the app: a white theme. Quite some Android apps have an either black (what you're using now) or white theme, which can be changed by the user in the settings. I would like to see a white theme too
(Or maybe even, as some apps have, multiple themes like white, red, blue, orange etc.)
Thanks anyway, for your effor of creating the app.
