New user of musicbee from using mediamonkey. All artwork visible in musicbee and is embedded in files.
However on remote library album view no album art is visible.
However in "now playing" the album art for the track is visible.
Any help welcome, many thanks
Hey MalvGuy,
This is a bug and I am not sure of the cause at the moment. It seems that there is a state issue because according to users it works if you clear the data, but it happens again after a while. I have something in mind that I would like to try. Hopefully, depending on the available time I will start working on a fix soon. Would you be available to give it a try? If so please reach out to me via e-mail.
Hi MalvGuy/Kelsos,
Caching of Album Arts is happening under two conditions.
1. When we start Musicbee
2. When we Invalidate the covers.
When new albums are added to Musicbee, and sync using Remote, album arts are not shown in Remote. This can be solved by restarting MusicBee in your system and syncing from Remote.
