v.0.12 looks pretty good
Two things, I noticed:
My OnePlus One is set on a low DPI for getting everything smaller. it runs @350dpi. The standard value is 450 i guess.
I think the low DPI is the reason, why the Album Cover is cut at the top and bottom for approx. 15%. So it isn't perfect square..
That doesn't look good :/
Second thing; when LastFm scrobbling is enabled while starting the App, the Checkbox isn't enabled.
Only if you disable and enable Scrobbling via the App, the Checkbox is checked.
Carry on
Your work is excellent
